How to add Calendly to a Weebly site
You can embed your Calendly page on your Weebly website to let visitors schedule time with you without leaving your site. Weebly supports all three Calendly embed types:
  • Inline embed
  • Popup text
  • Popup widget
Embed Calendly in Weebly
Follow these steps to add your Calendly embed code to a Weebly page:
  1. Sign in to Weebly and select Edit Site
  2. Under the Build tab, select the page where you want to add Calendly
  3. In the left-hand Basic toolbar, find the Embed Code element
  4. Drag the embed element into position on the page
  5. Select inside the element and choose Edit Custom HTML
  6. Paste your Calendly embed code from your Calendly account
    • You can use an inline, popup text, or popup widget code
  7. Select Publish to apply the changes to your live website
