Embed options for Weebly
Weebly supports all three of Calendly's embed options:
  • Inline
  • Pop-up text
  • Pop-up widget
How to embed Calendly in Weebly
  1. Sign in to Weebly and select Edit Site.
  2. Under the Build tab, select the page you'd like to edit, and use the Basic toolbar on the lefthand side.
  3. Locate the option to add an embed code, and drag it into position on the page.
  4. Edit the custom HTML within the box by pasting the embed code from your Calendly account.
  5. Publish the changes to your website.
