IN THIS ARTICLE
Which version of Wordpress do I have?
Log in to Wordpress and visit the admin dashboard of your account. Hover your cursor over the W logo in the top left corner of the page. Wordpress.org users will see a drop-down menu appear with options. If no menu appears, the account is on Wordpress.com.
Embed options for Wordpress.com
Add a hyperlink to your scheduling page on a Wordpress.com site and invite visitors to schedule with you. While editing one of your pages, highlight any text and click the Insert/edit link button in the toolbar. Paste the URL to your personal scheduling page, an event type page or a team page. To an image, select the image and follow the same steps.
Embed options for Wordpress.org
Wordpress.org supports Calendly's embed options including inline, pop-up text and pop-up widget. If you've applied a theme to your website, it may affect the appearance of the embed code.
To embed Calendly on a single page of your site, sign in to Wordpress and visit the admin area. Go to Pages and decide which you would like to edit, then click the + to add a new block. Choose a Custom HTML from the Formatting drop-down list, and paste the embed code that you copied from your Calendly account. Preview Changes to ensure the embed cooperates with your website's theme before selecting Update to save.
To apply the pop-up widget embed across your entire site, navigate to the Appearance section and open the Editor. Locate the Theme Files sidebar to the right of the page and scroll to find the Theme Footer. Locate the </body> tag at the bottom of the footer and paste the pop-up widget code that you copied from your Calendly account just above it.
