How to add Calendly to a Wix site
Embed Calendly on your Wix site so visitors can schedule time with you without leaving the page. Wix supports both inline and popup widgets.
Get your embed code
Before you begin, generate your Calendly embed code. You can get a code for:
  • A single event type
  • Your full booking page
Embed Calendly using the Wix editor
Follow these steps to add Calendly to your Wix site:
  1. Sign in to your Wix account.
  2. Select Edit Site to open the Wix editor.
  3. Select the + (Add) button.
  4. Go to Embed & Social and choose Embed Code.
  5. A resizable embed widget appears on your page.
  6. Select Enter Code.
  7. Paste your Calendly embed code.
  8. Select Update to apply the code.
  9. Use Wix’s layout tools to adjust the widget's size and position.
  10. Select Publish to update your live site.
For help resizing or positioning the widget, see Wix’s widget customization guide.
Embed Calendly using Wix custom code settings
If you prefer to use custom code instead of the visual editor:
  2. Go to Settings in your site's dashboard.
  3. In the Advanced section, select Custom Code.
  4. Select + Add Custom Code at the top right.
  5. Paste your embed code into the text box.
  6. Enter a name to help identify your code.
  7. Under Add Code to Pages, choose:
    • All pages: Applies the code across your site. You can choose to load it once per visit or on every page.
    • Choose specific pages: Use the menu to pick the pages you want.
  8. Under Place Code in, select Head.
  9. Select Apply to save your changes.
Link to Calendly with buttons or text
You can also share your Calendly link using text, buttons, or images instead of embedding the full calendar.
Add a link to text or an image
  1. Select the text or image on your page.
  2. Select Link > Web Address.
  3. Paste your Calendly URL.
Add a customizable button
  1. Select the + (Add) button.
  2. Choose Button and place it on your page.
  3. Edit the button text (e.g., “Book Now”).
  4. Select Link > Web Address.
  5. Paste your Calendly URL.
