While the Calendly extension is designed for Google Chrome, Google Chrome extensions can also be used in Microsoft edge. To add the Calendly extension to your Microsoft Edge browser, follow these steps:
From the top of any Calendly page, select Account, then Apps.
- At Calendly for Chrome, select View on Chrome Web Store.
In order to install Chrome extensions on your Edge browser, you will need to select Allow extensions from other stores from the banner at the top of the page. Then, select Allow to confirm.
Select the Calendly extension, then select Add to Chrome.
From the pop up, review the extension permissions and select Add Extension.
(Optional) If you haven't synced your extensions with all of your computers and want to do so, select Turn on sync in the pop-up and sign in with your Microsoft credentials.
Once complete, a pop-up prompt will appear to confirm that the extension has been successfully added.
See also:
Using the Calendly for Chrome extension
How to use the Calendly for Chrome extension
How to use Calendly for Chrome to copy your scheduling page link
How to use Calendly for Chrome to paste available dates into an email
How to use Calendly for Chrome to create a "single-use link" for your scheduling page
How to use Calendly for Chrome to create a one-off meeting
