To add the Calendly extension to your Microsoft Edge browser, follow these steps:
From the top of any Calendly page, select Account, then Apps.
- Select Calendly for Edge. You will be redirected to Edge's add-ons page.
Select Get.
(Optional) If you haven't synced your extensions with all of your computers and want to do so, select Turn on sync in the pop-up and sign in with your Microsoft credentials.
Once complete, a pop-up prompt will appear to confirm that the extension has been successfully added.
