How to edit an event type's scheduling link on mobile
You can update an event type's scheduling link from your mobile device anytime. It’s quick and simple.
Update an event type's scheduling link
  1. From the mobile homepage, tap the event type you want to edit.
  2. Tap Edit meeting type.
  3. Tap More options.
  4. Under Booking link tap the current link and enter your new link text.
  5. Tap Save.
When you change your link, the old one stops working. Invitees must use the new link to schedule with you.
