With the Calendly mobile app, you can manage your availability on the go. Create schedules, update existing ones, and set custom hours for a single event type in just a few taps.
Create a schedule
Saved schedules are reusable across multiple event types. If you only need hours for one event, you can set a custom schedule.
- Open the Calendly app.
- Tap your Account icon > Availability.
- Tap Create new schedule.
- On the Hours tab, set the recurring weekly times you want to be available.
- Select the days you want.
- Turn on Use same hours for all days to apply one set of hours across them.
- Adjust time blocks as needed:
- Tap a block to change its start or end time.
- Add another time block by tapping the + icon.
- Remove a time block by selecting the trash can icon.
- On the Overrides tab, set exceptions for specific dates without changing your weekly hours.
- When you’re finished, tap Save.
- Enter a name for your schedule, then tap Save.
- Choose the event types you want this schedule to apply to, then tap Done.
Edit a schedule
From your Availability settings
- Tap the schedule you want to edit.
- Update your availability:
- Use the Hours tab for recurring weekly times.
- Use the Overrides tab for specific dates.
- Change, add, or remove time blocks the same way as when creating a schedule.
- Tap Save.
From an event type
- From the homepage, select an event type.
- Tap Edit meeting type > Availability.
- Under Schedules, find your schedule and tap Review and edit.
- Tap Save.
Manage a schedule
From the Availability page, tap the three dots next to a schedule to see more options:
- Rename – change the name of the schedule.
- Set as default schedule – make this the schedule that applies to new event types by default. Your default schedule is marked with a star icon and is listed at the top of the Availability page.
- Duplicate – copy the schedule and make a new one with the same hours.
- Review linked event types - see which event types are using this schedule. From here, you can also assign or remove event types.
- Delete – permanently remove the schedule. Event types that use this schedule will keep those hours as custom availability unless you reassign them first.
Use a custom schedule for an event type
A custom schedule is availability you set just for one event type. It does not become a saved schedule that can be reused elsewhere.
- Under Schedules, scroll down to the bottom of the list and tap Use a custom schedule.
- Set your hours on the Hours tab (recurring weekly times) or the Overrides tab (specific dates).
- When you’re finished, tap Save and apply.
