Integrating Calendly with HubSpot can streamline your scheduling process and improve your workflow. However, it's not uncommon to encounter issues when setting up and using the integration. Here are some frequently asked questions and troubleshooting tips to help you get the most out of the Calendly-HubSpot integration.
My HubSpot form keeps redirecting to a thank you page and not a Calendly booking page, how do I fix that?
If leads aren't being directed to a Calendly booking page after submitting a HubSpot form, you can adjust the form's settings. To adjust the form's settings:
- Go to your form in HubSpot.
- Navigate to the Options tab.
- Adjust your “What should happen after a visitor submits this form” setting to not “Display a thank you message.”
Troubleshooting HubSpot forms and Wix
If nothing happens after you paste the routing script onto your Wix website:
- Ensure you're on the paid version of Wix. The free version will not allow you to enter custom code outside of an iframe.
- Paste the following code in the Custom Code/Body-start area found in the Settings section:
<!-- Calendly inline widget begin -->
<link href="https://assets-staging.calendly.com/assets/external/widget.css" rel="stylesheet">
<script type="text/javascript" src="https://assets-staging.calendly.com/assets/external/forms.js" async></script>
<!-- Calendly inline widget end →
If your invitees are not redirected away from the form when they exit the booking page before scheduling:
- Add the following code to your page template to redirect visitors when they close out the popup:
constcallback = (mutationList, observer) => {
for (constmutationofmutationList) {
if (mutation.type === 'childList') {
mutation.removedNodes.forEach((removedNode) => {
if (removedNode.className === 'calendly-overlay') {
window.open('https://calendly.com', '_self')
constobserver = newMutationObserver(callback);
observer.observe(document.getElementsByTagName('body')[0], { childList:true });
- Replace the Calendly URL in the snippet with the redirect URL that you want to use.
- Add the following code below the Calendly.initHubSpotForm({ url: ... }) line as following:
<!-- Calendly routing form code begin -->
<linkhref="https://calendly.com/assets/external/widget.css"rel="stylesheet">
<scriptsrc="https://calendly.com/assets/external/forms.js"type="text/javascript"async></script>
<scripttype="text/javascript">
window.addEventListener('load', () => {
Calendly.initHubSpotForm({ url:"..." })
<Add the code snippet here>
</script>
<!-- Calendly routing form code end -->
