Troubleshooting routing from Pardot forms
NOTE: This feature is currently in beta.
This article contains common troubleshooting steps related to Calendly routing from Pardot forms.*
*NOTE: Routing from Pardot forms is in closed beta and no longer accepting new beta requests.
I'm not seeing any forms to import.
Check out a common list of reasons why you're not seeing any forms to import below:
  • You're using Pardot “form handlers” and not Pardot native forms.
  • The user you used to connect Salesforce is not a user in Pardot.
  • You are a user in Pardot, but do not have access to create/edit Pardot form templates.
  • The Pardot instance is not hosted on a custom domain. For example, go.pardot.com is not a custom domain, but go.calendly.com is.
I'm not seeing my form's fields.
I’ve connected Pardot and I was able to select a form to import, however, I am not seeing any of my form’s fields in Calendly.
  • In this case, you likely have Cloudflare and have added your Pardot domain to Cloudflare.
  • To resolve this, you'll need to whitelist the Pardot domain from Cloudflare.
Cloudflare requires you to be on a higher tier to do this.
