Note: To embed Advanced Routing with Marketo, you'll first need to import a Marketo routing form.
- Check out this help center article for information on how to import a Marketo routing form into Calendly: Advanced Routing with Marketo Forms
- Check out this help center article for information on how to embed a Marketo form to your website: Embed a Form on Your Website.
Step One: Generate and copy the Advanced Routing embed code.
To embed Advanced Routing with Marketo, you'll first need to generate the code that you'll place on the website containing your Marketo form.
- Navigate to the Routing Forms panel from your Calendly home page.
- Select Share to the right of the routing form you'd like to embed.
- Select Copy.
Step Two: Paste the Advanced Routing embed code onto the web page containing your Marketo Form.
Copy and paste this script into your website after the Marketo embed code to run routing logic in Calendly for when a user submits your Marketo form
- Open your web hosting platform.
- Select the Embed from the web panel (or your web provider's equivalent).
- Paste the routing form embed code after the Marketo embed code.
- Select Save.
