How to embed routing from Pardot forms
To embed Advanced Routing with Pardot, start by importing a Pardot routing form into Calendly.
  • For instructions on importing Pardot routing forms into Calendly, check out this article.
  • For steps on embedding a Pardot form to your website, review Salesforce's article
Generating and copying the Advanced Routing embed script
  1. From your Calendly home page, navigate to Routing page.
  2. Find the form you’d like to embed, and select Share to the right of it.
  3. Select Share to the right of the routing form you'd like to embed.
  4. Under Step 1 in the Embed Code panel, select Copy to copy the script.
Inserting the Advanced Routing embed script in your Pardot form's Layout Template
  1. Navigate to Pardot.
  2. In the sidebar, expand Marketing, then Forms, and select Layout Templates.
  3. Locate the Pardot form you’re embedding, and under Actions, select the gear icon.
  4. Choose Edit to access the form's layout template.
  5. Paste the script copied in the previous step after the %%content%% tag within the script.
  6. Select Save in the bottom right.
Generating and copying the Advanced Routing embed code for your website
  3. Under Step 2 in the Embed Code panel, select Copy to copy the embed code.
  4. On your website, paste this code into your HTML above the Pardot form iFrame on your main site.
