To use Calendly, you'll need to use an up-to-date, supported browser. If you're using an out-of-date version of your browser, you may not be able to access Calendly or use all of its features. Keep your browser updated to its most recent version to ensure Calendly runs smoothly.
Note: Older operating systems may not support the most up-to-date version of your browser. If you're unable to update your browser due to an out-dated operating system, consider updating your operating system or device.
Calendly Supports the latest two versions of most major browsers, unless otherwise noted. Please review the lists below for more details.
Select the links below to download the latest versions:
Note: As of June 15, 2022, Calendly no longer supports Internet Explorer 11. For more information, check out Ending Calendly Support for Internet Explorer 11.
Select the links below for updating instructions:
Not sure which browser you're using? Use a tool like www.whatismybrowser.com to identify the browser you're using and confirm that it's up to date!
