Supported Browsers
To use Calendly, update your browser to the latest version. Older browsers may block access or limit features.
Calendly supports the two most recent versions of most major browsers. If you’re not sure which one you’re using, visit like www.whatismybrowser.com to check and update your browser as needed.
Some operating systems don’t support newer browsers. If that’s the case, consider updating your device or operating system.
Supported desktop browsers
Visit the links below to update your browser:
Supported mobile browsers
Supported tablet browsers
