Finding your Marketo credentials
NOTE: This feature is currently in beta.
In order to import a Marketo form into Calendly, you will first need to integrate your Marketo account. To do this, you will need three sets of alpha-numeric codes: Client ID, Client Secret, and Munchkin ID#.
Where to find Client ID and Client Secret
From the Marketo homepage:
  1. Select the Admin tab.
  2. Select Integration from the panel on the left side,
  3. Select Launchpoint. This will open up a window in Marketo called Installed Services.
  4. Select View Details.
  5. Copy the Client ID and Client Secret from here!
Where to find Munchkin ID#
The Munchkin ID# can be found under your Marketo Admin panel. Click on Munchkin.
...and copy the account ID.
