How to sign in to the mobile app if you use Calendly under a work profile on an Android
Use this procedure if:
  • you’re having trouble signing in,
  • you use an Android,
  • and you have Calendly installed under a work profile.
Go to the Play Store within your work profile and download a browser (we recommend Chrome). Note that you may need to contact the administrator of your work profile to enable a browser download.
Still having trouble? See What to do when you’re experiencing an issue with the mobile app.
