You can edit the status of your event type directly from the mobile app. Changing the status of an event type will hide the event type from your landing page and prevent new bookings.
To toggle the status of your event type, follow these steps:
From the mobile home page, select the event type you’d like to edit.
Underneath Status, tap the toggle to turn your event type off.
Once the status has been changed, your event type will no longer be visible and invitees will no longer be able to book using the scheduling link.
If you would like to mark your event as Secret, you can do so from a mobile or desktop browser. Secret events are not visible on your landing page, but can still be booked using the scheduling link.
To access this setting from your mobile app, follow these steps:
Select Edit all event type details to open Calendly in a mobile browser.
- If you haven't already, log in to your Calendly account. Once logged in, your event settings will automatically be visible.
- From the event settings, select When can people book this event.
- Then select Additional rules for your availability.
- Mark the check box to Make this a secret event.
- Select Save and Close, then select Done to exit your browser and return to the mobile app.
This change will automatically be reflected on your Calendly landing page.
