How to adjust the available start times for an event from the mobile app
  1. From the mobile homepage, select the event type you’d like to edit.
  2. Scroll to the bottom of the screen and select Edit this event type.
  3. Select When can people book this event? to expand the section.
  4. At the bottom of the section, select Additional rules for your availability.
  5. At Start time increments select the increments in which available start times will appear. The shorter the increments, the more start time options your invitee sees.
  6. Scroll to the bottom and select Save & Close, then select Done.
Was this article helpful?
5 out of 17 found this helpful
