How to add extra time before or after events from the mobile app
  1. From the mobile homepage, select the event type you’d like to edit.
  2. Scroll to the bottom of the screen and select Edit this event type. This will open a separate webpage with your Calendly application.
  3. Select When can people book this event? to expand the section.
  4. At Want to add more time before or after your events, select the boxes to choose the amount of time you want to add either before or after your event.
    Note: We suggest you only add time before or after an event, not both, to prevent booking conflicts.
  5. Scroll to the bottom and select Save & Close, then select Done.
Was this article helpful?
5 out of 9 found this helpful
