How to delete additional schedules you no longer use
  1. From any Calendly page, select Availability.
  2. Select the arrow next to your schedule name, then select the schedule you want to delete.
  3. Select the gear icon, then select Delete.
    Note: Deleting a schedule can’t be undone. Any event types associated with this schedule will be set to custom availability hours.
Was this article helpful?
12 out of 39 found this helpful
