If you are on our Teams plan and would like to add single sign-on (SSO) features to your Calendly account, please contact our Sales team and they would be happy to assist you. The SSO add-on costs $3 per user, per month.
As a member of an organization that uses single sign-on (SSO), use this procedure to log in to Calendly using your organization’s SSO credentials.
From calendly.com, select Log In.
Enter your email associated with your organization and select Continue.
Select Login with Single Sign On.
You’ll be redirected to your organization’s identity provider (IdP).
Depending on your organization’s IdP, you might have to log in using your IdP credentials. If not, you’ll be redirected to your Calendly home page.
