How to sign in using single sign-on or SSO
As a member of an organization that uses single sign-on (SSO), use this procedure to log in to Calendly using your organization’s SSO credentials.
  1. From calendly.com, select Log In.
  2. Enter your email associated with your organization and select Continue.
  3. Select Login with Single Sign On.
You’ll be redirected to your organization’s identity provider (IdP). Depending on your organization’s IdP, you might have to log in using your IdP credentials. If not, you’ll be redirected to your Calendly home page.
Was this article helpful?
6 out of 20 found this helpful
