How to update your schedule for multiple event types
Calendly allows you to edit your schedule for multiple events all at once.
  1. From your Home page, select Availability.
  2. If you have multiple schedules, select the drop down menu and then the schedule you'd like to apply.
  3. Select the box next to Applied to, then select the event types you want to apply this schedule to.
  4. Select Apply.
  5. To make changes to your schedule, view How to change your schedule. Once you finish updating your schedule, Calendly automatically saves it and updates any event types the associated with the schedule.
Was this article helpful?
19 out of 62 found this helpful
