How to set your default schedule
If you have multiple schedules, use this procedure to set a default schedule. Your default schedule is defined by a gold star.
Note: Calendly automatically uses your default schedule to determine which time slots invitees can book.
  1. From any Calendly page, select Availability.
  2. Select the down arrow next to your current default schedule, then select the schedule you want to set as your default schedule.
  3. Select the gear icon next to the schedule name, then select Set as default.
Was this article helpful?
15 out of 64 found this helpful
