Save time in the setup process and use a pre-built, common workflow
- From your Home page, select Workflows. Review the pre-built, common workflows on the page and select Use workflow on the one you want to use.
- At Workflow Name, enter a name for the workflow.
- At Which event types will this apply to, select each event type that you want to use this workflow, then select Apply.
- In the Do this section, select Edit then customize the message as desired.
- To automatically add information from your event type or information about your invitees to the message, place your mouse pointer where you want to add the data, select Variables then choose an item from the list and Calendly will replace them with actual values from your event or invitees. Repeat this step to add additional variables.
- To add more actions, click Add action, repeat steps 4 & 5, then select Next.
- Select Done, then Save.
Workflows for Team Event Types
As a Calendly admin or owner, you can create Workflows for your teams collective and round robin event types. The process for creating and editing workflows is the same for individual, shared, and team event types. However, for team events, you will need to navigate to your team page.
Workflows for Shared Event Types
As a Calendly owner, admin, or shared event type owner, you can create Workflows for shared events. The process for creating and editing workflows is the same for individual, shared, and team event types. To view ownership of a shared event:
- From the Even Types page, select the settings icon in the top right-hand corner of the shared event.
- Select Edit permissions.
- From the People with access section, owners, admins, and shared event owners can view and edit the permissions for each user assigned to the event.
Note: If you can't see a settings icon on a shared event, this indicates that you have 'Can view' access. To obtain edit permissions, you'll need to contact the owner of your organization, an admin, or the owner of the shared event.
Workflows for Managed Events
Managed Workflows give Calendly owners and admins the ability to create, update, and lock Workflows for the Managed Events that are assigned to users in the organization. To learn more, check out How to set up Admin-Managed Workflows.
