How to edit hosts for shared events
If you create a shared event type, you are automatically assigned as a host. Hosts can edit or remove themselves from the event they are assigned to. Use this procedure to add or remove additional hosts from a shared event type:
  1. On your Home page, find the shared event type you want to edit hosts for.
  2. Select the shared event type to edit.
  3. Select Edit Hosts at the top of the page.
  4. At Who will be part of this event type, add new hosts via name or email or select Remove to remove hosts from participating in the shared event.
  5. Select Update.
Note: Next to the Edit hosts and Remove me links, there is a tag where you can see who last edited the shared the event type.
See also:
How to set up a collective shared event
How to set up a round robin shared event
Was this article helpful?
6 out of 17 found this helpful
