How to hide your personal email (use a no-reply email address)
Normally Calendly sends notifications using the email address that's associated with a calendar you connected to Calendly. You can choose to use a "no-reply email address" to hide your personal email; Calendly then uses "notifications@calendly.com" as return address on notifications. This applies to email confirmations, email reminders, and email follow-ups.
  1. From the Event Tab of your Home page, click the event.
  2. Expand the Notifications and Cancellation Policy section.
  3. To have Calendly use a "no-reply" return address, in the Calendar Invitations section, select Switch to Email Confirmation then select Use a no-reply email address at the bottom of the page.
  4. Select Save & Close.
When messages are sent using a "no-reply" email address, a message appears at the bottom informing recipients that the email should not be used for a reply and is only intended for sending messages. If recipients do reply, the email is sent to an unmonitored email inbox and will not be received.
Was this article helpful?
48 out of 69 found this helpful
