How to specify which calendars Calendly adds events to and checks for conflicts
Before you begin…
  • Calendly can only add booked events to one calendar.
  • If you have multiple calendars within a single account, you can use this procedure to specify exactly which calendars Calendly checks for conflicts.
  1. At the top of any Calendly page, select Account, then Calendar Connections.
  2. Screen_Shot_2020-03-29_at_11.52.54_AM.pngTo specify the calendars Calendly uses to determine when you are free or busy, in the Check for conflicts section, select Edit, select a calendar, then select Update.
  3. To specify the calendars Calendly adds new event to, in the Add to calendar section, select Edit:
     - select a calendar
     - to have Calendly automatically delete events you remove from the calendar, at Sync cancellations check the box.
    - select Update.
Was this article helpful?
67 out of 197 found this helpful
