This article covers how to manage Routing Forms by editing permissions, viewing responses, and exporting results to stay on top of important form data.
Editing Routing Form permissions
- Navigate to your Routing page and open the form you want to edit.
- At the bottom of the page, select Edit permissions.
- Enter the name or email of the user you want to add.
- Once you've added those users, select Apply to save your changes.
Viewing Routing Form responses
- Navigate to your Routing page.
- Locate your form, and select the three dots next to it.
- Select Responses.
Alternatively, you can access the Responses tab inside the form.
You'll be able to view the response date, destination result, questions, and answers. You can also use filters, such as result type, event type, and date range to narrow down the responses.
Exporting Routing Form responses
Once your Routing Form is live and has collected responses, you can export the results as a CSV file.
- Select Export results.
Alternatively, you can export responses from the Responses tab inside the form.
Exporting a large number of responses may show a "Queued" message, and the results can take up to 24 hours to be delivered by email.
