Contacts make it easy to see who you're meeting with, review notes and scheduling history, and book follow-up engagements directly from Calendly.
Currently, the mobile app does not support the removal or editing of Contacts. To remove or edit existing contacts, please use the Calendly web application.
Create a Contact
Contacts are automatically created for each invitee that schedules with you from 2024 and beyond. You also have the option to manually add contacts within your Calendly account.
- Select the + icon from the home screen.
- Select Create new contact.
- Enter contact Name and Email Address.
- (Optional): Enter contact Phone Number and Timezone.
- Select Save and continue.
Share availability
From the mobile app, you can share your availability with existing contacts using a link, text, or email.
- Navigate to Contacts and select the contact you would like to meet.
- Select Share availability.
- Select the event you want your invitee to schedule with you.
- Select Share link.
- Select how you would like to Share availability.
Review contact specific meetings
Review scheduled meetings within Calendly for a specific contact within their contact card.
- Navigate to Contacts.
Select the name of the contact you are looking to review meeting history for.
Mark as no-show
Mark contacts as a no-show for past meetings directly from the mobile app.
- Select the name of the contact to mark as no-show.
- Select the past meeting that was missed.
- At the bottom of the page, select Mark as no-show.
