Unbounce supports Calendly's embed options including inline, pop-up text and pop-up widget. Sign in to Unbounce and open the page you'd like to edit by choosing Edit Champion Variant from the gear menu.
Hover over the menu options to the left of the window to locate Custom HTML, then click and drag the button onto the page. In the popup window, paste the embed code copied from Calendly for your personal scheduling page, an event type page or a team page. Save the code, then click and drag or resize the placeholder into position.
You may see an error warning that the HTML block is invalid. Save the changes to the page and use the Preview button to ensure the embed functions normally. If you've applied a theme to your website, it may affect the appearance of the embed code.
