Booking over scheduled meetings
Private Beta Feature
The ability to book over scheduled meetings is currently in private beta. During private beta, this functionality can only be set up to book over non-Calendly created meetings. Once this feature is fully released, functionality will also include the ability to book over Calendly created meetings as well.
These event settings allow you to open up more time within your calendar than what is typically indicated as free. This provides you with more flexibility in setting and managing your availability within Calendly.
  • This functionality allows you to:
    • Book over/override reserved times on your calendar
    • Book over/override events where you are optional to attend on your calendar
    • Book over/override events 60 days into the future
  • This functionality does not allow you to:
    • Book over Calendly scheduled events
Set up the ability to book over scheduled meetings
Setting up the ability to book over scheduled meetings can be done within your event editor. You can set this up by following the steps provided:
  1. Select the event type you are looking to book over scheduled meetings for.
  2. Navigate to the Scheduling settings section of your event editor.
  3. Open up your Available hours setting.
  4. Scroll down to the Additional host settings section.
  5. Select specific events from your connected calendars to allow to be booked over.
  6. Select Save and close.
