How to change the duration of an event type within the mobile app
Before you begin...
When you change the duration of an event type, it will not apply to scheduled events that invitees have already booked with you.
  1. From the mobile homepage, select the event type you’d like to edit.
  2. Select the current Duration
  3. Select a new duration time. If the duration time you would like is not listed, choose Custom length of time and adjust the amount of hours and minutes.
  4. Select Done.
Was this article helpful?
6 out of 71 found this helpful
