How to limit the number of events booked daily from the mobile app
  1. From the mobile homepage, select the event type you’d like to edit.
  2. Scroll to the bottom of the screen and select Edit this event type.
  3. Select When can people book this event? to expand the section.
  4. At the bottom of the section, select Additional rules for your availability.
  5. At Maximum allowed events per day for this type of event, select the maximum number of events that can be booked daily for that event type.
  6. Scroll to the bottom and select Save & Close, then select Done.
NOTE: Calendly's "maximum allowed events per day" restriction, when set, will not apply to the total number of Calendly events across all event types. This setting is event specific.
