How to change the name of an event type within the mobile app
Before you begin...
When you change the name of an event type, it will not apply to scheduled events that invitees have already booked with you.
  1. From the mobile homepage, select the event type you’d like to edit.
  2. Select the current event type name.
  3. Under Event type name, select the current name and to delete the current text.
  4. Begin typing to add a new event type name.
    Note: Changing the event type name will not affect the scheduling page link. To update your link as well, see How to customize an event type scheduling link in the mobile app.
  5. Select Done.
