Calendly sends and stores Calendly routing form responses in Salesforce, automating creating/updating Salesforce records (by default, contacts and leads). This makes it easier to centralize reporting, while also enabling retargeting a qualified lead who didn't book a meeting.
To learn more about routing forms, check out this Help Center article: Getting started with Routing Forms
Note: Syncing Calendly routing form responses to Salesforce is included in package version 2.4 or higher. If you are unsure of what version you currently use, visit your Salesforce integrations page to confirm your version.
How it works
When a Calendly routing form is submitted, the Salesforce integration creates a CalendlyRoutingFormSubmission record and a CalendlyRoutingFormQuestionsAnswers record for each question asked on the form. The creation of the CalendlyRoutingFormSubmission record triggers the flow CreateRoutingFormLeadTemplate.
This flow is fully customizable, but works in the following way by default:
- The flow looks for a contact that matches the SFID.
- If the flow finds a contact, it associates the form submission to the contact by updating the Calendly Contact field on the CalendlyRoutingFormSubmission record to the Contact ID.
- If the flow does not find a contact, it looks for a lead that matches the SFID.
- If the flow finds a lead, it associates the form submission to the contact by updating the Calendly Lead field on the CalendlyRoutingFormSubmission record to the Lead ID.
- The flow loops through the CalendlyRoutingFormQuestionsAnswers records related to the CalendlyRoutingFormSubmission until it finds a name question. This will be the lead's name if the flow can't find a record matching an email address.
- The flow then loops through the CalendlyRoutingFormQuestionsAnswers records related to the CalendlyRoutingFormSubmission until it finds an email question. This will be the email address the flow uses to look for a matching record and if the flow can't find one, this will be the new lead's email.
- If the flow can't find an email, it ends since the flow won't create a Lead by default without an email address.
- If the flow finds an email:
- It looks for a contact that matches the email address.
- If the flow finds a contact, it associates the form submission to the contact by updating the Calendly Contact field on the CalendlyRoutingFormSubmission record to the Lead ID
- If the flow does not find a contact, it creates a new lead that will be owned by an active system admin.
- The flow then associates the form submission to the lead by updating the Calendly Lead field on the CalendlyRoutingFormSubmission record to the Lead ID.
There is a FormSubmissionsUUID field on the Calendly field on the CalendlyAction object.
While the above custom object and flow is only triggered by the Calendly-hosted forms not integrated behind a marketing automation tool form (Pardot, Marketo, Hubspot), we will still pass a value to this field on the CalendlyAction object if the event was scheduled after the invitee completed any form that was in front of a Calendly routing rule.
This means if you want to handle events from a form differently from events booked by directly visiting a Calendly link, you can customize your CreateEventTemplate flow to branch based on whether or not this field is null.
