With our Stripe integration, you’ll be able to collect payments from invitees at the time an event is scheduled. You can save time and reduce no-shows by connecting your Stripe account to Calendly and allowing clients or customers to submit payments when choosing a time to meet with you.
IN THIS ARTICLE:
How to connect Stripe with Calendly
To get started, log into Calendly and visit your Integrations page. Select the option for Stripe Payments and connect your Stripe account. If you do not have a Stripe account, you will be prompted to create one.
Collect payments from your event types
Once Stripe is connected to your Calendly account, you can add payments to new or existing event types from your Event Types page. Just select the event type you would like to edit and expand the Collect Payments section to enable the "Accept payments with Stripe" setting.
From there, specify the amount to be collected when an event is scheduled. Keep in mind, that this amount will be in US dollars. Customize your payment terms with any information an invitee may need before confirming their payment. Add your cancellation policy or specify additional fees to come later.
By default, only an invitee’s credit card number and expiration date are required. If you would like to require other fields, you can update your settings in Stripe.
Stop collecting payments from an event type
You can make any paid event type free by choosing the “Do not collect payments for this event” setting within the Collect Payments section.
To disconnect Stripe from your Calendly account completely, visit your Integrations page, select the option for Stripe Payments and click Disconnect. Any event types accepting payments at that time will become free once Stripe is disconnected.
