How to customize once and share your event on mobile
You can now customize event details when sharing from the Calendly mobile app. There's no need to create a new event type.
Your changes apply only to the link you're sharing. They won't affect your original event types. This lets you personalize the event for each invitee.
For steps on customizing events from your desktop, check out this article.
This feature is only available for one-on-one event types that aren’t admin-managed.
  1. Download the Calendly app from the App Store or Google Play.
  2. Sign in to your Calendly account on your mobile device.
You’ll be able to edit the following details:
  • Event name
  • Event duration
  • Event location
  • Date range
  • Availability schedule
Customize once and share your event
  1. Open the Calendly app. Tap the event type you'd like to use.
  2. Tap More share options.
  3. Choose Customize once and share.
  4. Update your event details (name, location, duration, and availability).
  5. Tap Share Link. Choose how you'd like to send it.
