How to customize events once and share
Customize your event details directly on the sharing page to tailor one-on-one event types for a specific invitee. Adjustments can be made without creating a new event type, saving time and effort. This feature works in the mobile app and is available for one-on-one event types only.
What you can customize
You can edit the following fields at the time of sharing:
  • event name
  • event duration
  • event location
  • date range
  • meeting hours
  • date specific hours
Customizing your event when sharing
  1. From your Calendly homepage, click the Share button for the event you want to use.
  2. Select Customize & share.
  3. From the next screen, make the desired edits.
  4. Click Share link.
  5. You will be returned to the sharing page.
If you have any Calendly Workflows connected to the original event type, those workflows will still be triggered with the customized version. If you change the title of the event, the Workflow will automatically update for the new version.
Customizing your event via extensions
You can also access this feature through our extensions for Calendly's web browser, Gmail, Outlook, and LinkedIn. The customization window will appear as a pop-up, and you can simply follow the steps outlined above!
