Calendly Salesforce package v2 post-install steps
Once you have installed the Calendly Salesforce package (version 2.3 or higher) from the Salesforce integrations page, we recommend taking the steps detailed in this article so that you can begin testing and customizing the integration behavior.
Flow templates deactivated by default
Usability updates to our managed package (v2 or higher) now sets flow templates to be deactivated by default. This is following Salesforce's best practice guidelines so that flow template updates from Calendly can be intentionally added to the flow by the Salesforce admin instead of impacting the instance by default. Therefore, we recommend creating a copy of the deactivated default flow templates and activating the copy of the flow templates.
Creating a copy of a flow template
Note: Once a copy of the flow templates has been created and activated, we recommend creating a test booking in Calendly to verify the flow is functioning properly.
Steps to copy a flow template
  1. From your Salesforce Flows list, select the flow template you wish to duplicate (i.e. MapCalendlyLinkTemplate).
  2. Select Save As in the top right-hand corner.
  3. Name the flow by creating a Flow Label
  4. Select Save
  5. Navigate back to the Salesforce Flows list
  6. Select the newly saved/created flow.
  7. Activate the flow by selecting Activate in the top-right hand corner.
